Help center
Pricing
Get a demo
Guides & support
Getting started
Getting started
For sites
Install a container (with a tracking code)
Angular: install a container (with a tracking code)
Google Tag Manager: install a container (with a tracking code)
Google Tag Manager: install a tracking code on its own
Install a first-party collector (server-side)
Instapage: install a container (with a tracking code)
Next.js: install a container (with a tracking code)
No Piwik PRO Tag Manager: install a tracking code
React: install a container (with a tracking code)
Shopify: install a container (with a tracking code)
Squarespace: install a container (with a tracking code)
Wix: install a container (with a tracking code)
WooCommerce: install a container (with a tracking code)
WordPress: install a container (with a tracking code)
For mobile apps
Android SDK: install a tracking code
Flutter: install a tracking code
iOS SDK: install a tracking code
React Native: install a tracking code
Debug
Check to see if your web tracking is working correctly
Collect additional data
Set up ecommerce tracking
Set up goals
Create a custom dimension
Create a custom event
Set up a user ID
Organize data
Set up a funnel report
Set up a user flow report
Use dashboards to organize data
Group visitors into segments
Use meta sites to merge data
Settings
About site or app settings
About global site & app settings
About tracking code settings
About JavaScript tracking API
Migrations
Migrating from GA3/GTM
