What can I use Piwik PRO for?
The Piwik PRO Analytics Suite allows users to quickly gain powerful insights with data segmentation, data activation, user-centric reporting, and painless tag implementation while ensuring complete data security. With Piwik PRO Intranet Analytics you get an in-depth understanding of your organization’s internal communication system. Moreover, all the clients are assigned a dedicated Customer Success Manager, who is there help you create the tailored implementation plan based on your specific business goals and KPIs, to ensure you are happy with the tool and the insights it provides.
Be the first to rate this article.
