Guides & support » Questions » For how long does Piwik PRO retain data?
We keep your visitor data as per your plan. With the Business plan, it’s 25 months, and with the Enterprise plan, it’s 25 months or a custom period.
Data retention starts from the first event we track. If data exceeds this period, it’s deleted on the first day of the following month, along with the data for the entire month. When you close your account, all your data is also deleted.
Here are the rules that we follow for each plan.
Business Enterprise (cloud and private cloud) Enterprise (on-premises)
Data retention period for visitor data (all sessions and events)
25 months
Note: You can upgrade for more.
25 months or a custom period Unlimited
Data is deleted after closing your account
Note: You can export each report or export raw data with our BI integrations.
Note: You can order a database dump before your data is deleted. You can also export each report or export raw data with our BI integrations.
Backups
Note: We retain backups as described in Data Processing Agreement.
Note: We retain backups as described in your individual Data Processing Agreement.
Other documents Note: We keep contracts, invoices and other business documents for as long as legally required.
