Guides & support » Questions » How long does Piwik PRO process data?
Piwik PRO processes data as follows:
  • Data access: Access to data is available within 2 hours after a visitor’s session ends. This delay is connected with the deduplication process. If you want to see real-time sessions, go to the tracker debugger.
  • Data calculation: Reports are quickly generated from raw data for any date range and segments.
