Here’s a list of actions tracked by Piwik PRO:
Basic actions
Action name | Tracked by default | Description |
Broken event | An event that wasn’t tracked correctly due to some error. Broken events are reported only in the tracker debugger and contain a message that can help you fix the issue. | |
Custom event |
A visitor performs a custom event. By default, Piwik PRO tracks as custom events: page scrolls and JavaScript errors. (Page scrolls can be turned off in Administration > Sites & apps > Data collection > Page scrolling > Measure scroll depth. JavaScript errors can be turned off in Tag Manager > Piwik PRO tag (tracking code) > UX issues > Detect JavaScript errors.) Other custom events can be set up additionally. |
Content impression |
A visitor sees a custom popup or content. It can be turned on in Tag Manager > Piwik PRO tag (tracking code) > Data collection > Interactions with popups and content.) |
Content interaction |
A visitor interacts with a custom popup or content. It can be turned on in Tag Manager > Piwik PRO tag (tracking code) > Data collection > Interactions with popups and content.) |
Custom ping | Any ping that is sent by the user. For example, a custom ping to inject the time after a visitor clicked on something. | |
Download | A visitor downloads a file. | |
Goal conversion |
A visitor completes a goal. Goals can be turned on in Analytics > Goals > Add a goal. |
Heartbeat ping |
A ping requests responsible for counting the time spent on a page. You can turn off heartbeat pings in Menu > Tag Manager > Tags > Piwik PRO > Data collection > Count session time precisely (off). Read more |
Internal search | A visitor uses your internal search engine. | |
Outlink | A visitor clicks the link to an external website. | |
Page performance metric | A ping request responsible for calculating page performance metrics used in the page timing report. | |
Page view | A visitor visits a page. |
Consent actions
Consent form impression | A visitor sees a consent form on your site. | |
Consent form click | A visitor clicks on a button on a consent form on your site. | |
Consent decision | A visitor makes a decision using a consent form on your site. |
Ecommerce actions
Ecommerce order | A visitor buys your product. | |
Abandoned cart | A visitor abandons the cart. |
SharePoint actions
SharePoint | Additional events tracked when you’re using SharePoint integration. |
Tip: For more on actions, see this article: Where can I see how many actions I’ve tracked this month?
